May 5, 200719 yr comment_175831 Can anyone tell me what the switches do on a KE70 5 Speed? I know one is for reverse which sits on the passenger side in the most rearward position, but there is one in front of that and one on top of the gearbox. What do these two mystery switches do? Cheers Raven Report
May 5, 200719 yr comment_175833 Do the KE70's have a cruise mode switch which is activated in a high gear and adjusts the carby for economy use? Report
May 6, 200719 yr comment_175853 Yep, thats the "lean running" solenoid switch. In my gf's 626 coupe I have it disconnected from the carb and patched into the suspension height controller through a relay so that when you select 5th it drops it down an extra 25mm Cool trick :S Report
May 6, 200719 yr Author comment_175860 Do the KE70's have a cruise mode switch which is activated in a high gear and adjusts the carby for economy use? Thats one of the switches. I'm wondering what the other one does... Report
May 6, 200719 yr comment_175863 ok I'm lost too now.... from the top of the box they go into the loom... I have no idea after that as they both seem to route into the cabin... Report
