August 24, 200422 yr Author comment_17430 wow - thanks for the complement fook; i suppose at one time or another every 1 has weird and wacky idea's lol But yeah, my spelling sucks; ill get there yet tho lol Report
August 24, 200422 yr comment_17438 So if we mix Teddy's theory of magnetic pistons and Fook's advice about less energy to push in one direction - then how about a magnetically pulse driven rotary - where each of three magnets pushs the rotor in succession - or more magnets - so it will provide drive much like the Tower of Terror ride at Dreamworld Report
August 24, 200422 yr comment_17439 But again, even a rotary engine doesn't do a perfect circle, well not exactly anyway, so more energy than necessary will still be lost. The reason behind why the design principles are different for an electric motor vs a combustion engine is cause of the way the movement is obtained. In an electric motor (using electro-magnets), the movement comes from the pulling power (attraction) and pushing power (repulsion) between the magnets and brushes. Compare this to a combustion engine where the movement comes from the expansion of the gases in the combustion chamber. That's why piston engines are designed the way they are (expansion pushes the piston down) and again the same with rotary engines (expansion pushes the rotor around). If you designed a combustion engine completely round (like an electric motor), it wouldn't work at all because the expansion of gases wouldn't push anything anywhere, unless you made it also vent the gases sideways like little jets or something... Report
August 24, 200422 yr Author comment_17455 I have thought up a new idea, but i will post it 2 morrow when i have fixed up the bugs in the design best to my ability ! Idea : Pre Compressed Air fuel mixture which is put into a spinning star fish shaped rotor :D :unsure: Report
