sleepercorty Posted August 10, 2007 Report Share Posted August 10, 2007 (edited) ive got a ke30 with ca18det at the moment has standard computer, standard turbo and dump pipe, has 2.5 inch exhaust and small intercooler. I bought a 180sx type x turbo off a sr20 (slightly bigger than a silvia sr20 turbo) which I'm going to fit to it as well as a 3 inch dump pipe, wondering if anyone has done the sr20 turbo onto ca and what kind of results they achieved. i will be doing it in a couple of weeks and dynoing it before and after but at the moment id say its making around 165rwhp and hoping for around 190rwhp when done. is that a resonable target? Edited August 10, 2007 by sleepercorty Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted August 20, 2007 Report Share Posted August 20, 2007 (edited) i wouldn t think you ll make 190rwhp with a standard computer and standard boost cut. but you may nissansilvia.com is a good source for this kinda info bud! Also what is a type x sr20 turbo? Sr's had t25g (s13) t28 (s14) and t 28 ballbearing(s15) Just a comparsion my mates ca18 made 212rwhp with a t28 and aftermarket ecu and bigger injectors on 13.5psi Edited August 20, 2007 by ca18rolla Quote Link to comment Share on other sites More sharing options...
philbey Posted August 20, 2007 Report Share Posted August 20, 2007 my old bluey made 150(198hp)kw with a remapped comp, a good exhaust, supra cooler, not sure of the boost. unsure if it was wheel or flywheel (new owner dynoed it), but either way, thats a good start for an essentially stock motor. And it was a formidable car to drive. in a 900kg rolla, it would be much much more formidable. Quote Link to comment Share on other sites More sharing options...
andro0o Posted August 20, 2007 Report Share Posted August 20, 2007 Also what is a type x sr20 turbo? Sr's had t25g (s13) t28 (s14) and t 28 ballbearing(s15) late model and all jdm s14s also had ball bearing. Quote Link to comment Share on other sites More sharing options...
Jordan Posted August 21, 2007 Report Share Posted August 21, 2007 150KW's at the treads on a GTiR T28, stock injectors, just 10PSI of love, on a fresh bottom end. Cheers Jordan Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted August 24, 2007 Report Share Posted August 24, 2007 mates datto runs 212 rwhp t28 ballbearing exhaust fmic and 14psi chipped computer just for some more info for u! Quote Link to comment Share on other sites More sharing options...
sleepercorty Posted September 4, 2007 Author Report Share Posted September 4, 2007 well results were alot better than i expected, the only mods the car has are 2.5 inch press bent exhaust with standard dump, small front mount and 11psi, with standard turbo made 178.6rwhp and with changing only the turbo to t25g made 203.7rwhp on 12psi. still has plenty of fuel for more boost so that is the next mod get rid of boost cut and see what around 16psi does. i have a feeling but that the standard injectors will ruin the party at about 220-230rwhp but time will tell. Quote Link to comment Share on other sites More sharing options...
Jordan Posted September 4, 2007 Report Share Posted September 4, 2007 don'tforget that Series 4 RX7 injectors are a drop in replacement, RB20 AFMs are easy to wire up and the ECU's remap great. Cheers jordan Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted September 5, 2007 Report Share Posted September 5, 2007 injectorsonline.com are cheap as for new injectors. They are who i always use.GO the 570cc h hah Quote Link to comment Share on other sites More sharing options...
