4k Into Ke35
hey I'm a noob here but i was wondering if anyone could guide me in wireing a 4k into my ke35 are there any major things i need to do when changing it over. cheers eddie
Unplug all sensors and wiring from your 3K (I'm assuming thats what is in there already)
Remove engine
Install 4K, bolting into the exact same things as the 3K
Install all plugs and sensors in exact same location as the 3K
There's basically nothing to it, the engines are essentially identical apart from internals/block height and carby
Remove engine
thanks mate thats what i wanted to know. cheers
make sure your dizzy isnt broken, and check all plugs and leads blabla
some imported 4k engines have finer pitch threads to bolt the belhousing to the engine just check your old ones screw in the new 4k before fitting. if they are different just go to a bolt shop like universal fastners and get some high tensile fine threads the same length.
