Sure will, the KE70 / AE71 steering arms have the same stud pattern at the bottom end.
You'll need to fit the KE55 strut tops to make it bolt in up top, as the 3 bolts have a different pattern.
AE86 struts fit into a KE55 if you use Corona steering arms. You can use the AE86 arms, but I'd advise against it as they don't have steering stops to stop you from rubbing your tyres on the inner guard, but if you have a welder... While you're there, score some corona LCA's too, definitely a worthwhile upgrade.
