August 29, 200719 yr comment_194546 Gday My KE70 runs fine, but randomly the heater stops working and the engine runs hot. Randomly the heater will start working again, and the car will not run hot anymore. Can anyone suggest as to what the hell is going on with my car? :D p.s. there is also a swishing sound like a lot of water moving, mainly during startup. I can't pinpoint exactly where the swishing comes from. It comes from the front of the car... Report
August 31, 200719 yr Author comment_194967 No, it was overheating seriously and i changed the thermostat, its new Report
September 2, 200719 yr comment_195125 p.s. there is also a swishing sound like a lot of water moving, mainly during startup. I can't pinpoint exactly where the swishing comes from. It comes from the front of the car... Sounds like there's air in the system, causing an air lock once warmed up (ie. water stops circulating) Check to see if fluid needs topping up, run engine without radiator cap on till it starts warming up and bubbling out, this should clear out any air in system, top up till full and put cap back on. If there's a continued coolant loss, may indicate further problems. If not the case, check water pump. Report
September 4, 200719 yr comment_195752 Phife makes a good suggestion there - you should always run it with the cap off until the thermostat opens up, as you will just about always get a drop in water level. Also, how hot is "running hot"? ie is the car boiling? and are you losing much water over a week etc? Report
September 4, 200719 yr comment_195769 Squeeze the bottom hose while it heats up with the cap off too. Speeds it up a bit when theres air to expel. If the only temperature gauge you have is the factory one you know its fiction right? Edit: Beerhead reckons turn the heater on while you fill and run the air out of the cooling system. Goo luck. Edited September 4, 200719 yr by LittleRedSpirit Report
September 5, 200719 yr comment_196062 cram a bottle in the radiator neck fill with water to create the highest point and allow car to heat up and open heater vavle should bleed it self if water pump is ok???? and thermostat is open Report
September 10, 200719 yr comment_197069 Are You sure the thermostat is not installed upside down i have seen it done before. Report
