October 13, 200719 yr comment_203100 i tried searching but didn't come up with anything regarding this, but since ke26 panel vans came out with steel plates instead of rear windows, can they be removed and replaced with actual windows? or are they welded in place or something like that. Report
October 13, 200719 yr comment_203109 not sure why anyone would want to as ke26 panelvans are very rare! Report
October 15, 200719 yr comment_203440 anyone stupid enough to put rear windows in a ke26 panno deserves to be shot. tell ya what if your panno is as good or better condition than my ke26 4 door well do a swap. u get your rear windows and i get my panno ive always wanted. cheers, scott Report
October 15, 200719 yr comment_203490 check them out , this one used to live near me years ago when it was REALLY nice , still looks ok KE26 Panel van Report
October 16, 200719 yr comment_203504 i knew the owner when it had a 5k. i'm sure my mate will buy this... Edited October 16, 200719 yr by JC807 Report
October 16, 200719 yr comment_203580 (place pick of overrated panno here) attempting to upload a good pick, it aint working. cheers, scott Edited October 16, 200719 yr by PMP020 Report
October 17, 200719 yr comment_203730 i tried searching but didn't come up with anything regarding this, but since ke26 panel vans came out with steel plates instead of rear windows, can they be removed and replaced with actual windows? or are they welded in place or something like that. I assume its done the same a the E7 pano's therefore The 'plates' are all part of the outer shell, so if you want windows there you'll have to cut the shell then get the windows and rubbers made up to fit.... I'd say a very expensive mod to do to a rare model... but would make it unique I guess Report
October 20, 200719 yr Author comment_204412 i just bought that ke26, so it'll be coming down to melbourne soon :lolcry:, which is why i was asking about the windows. but after seeing it up close i'd rather keep it the way it is. Report
October 20, 200719 yr comment_204423 are you going to finish the 13bt conversion? i believe its possible to engineer it because its a commercial vehicle. Report
October 21, 200719 yr Author comment_204451 yeh I'm gonna keep the 13bt in it, i just need to sort out better cooler as the top intercooler isn't all that flash. and i need better brakes! cos they are useless atm. Report
October 21, 200719 yr Author comment_204463 yeh it drives fine, hasn't been driven much lately and needs a tune bad as its running rich, but apart from that everything is done, just needs a tidy up. Report
October 21, 200719 yr comment_204481 we got pulled over by the cops once with 3 people in the back of that car. that was when it was first resprayed that metallic blue/green and i think it had a 5k. Report
