Ae71 Brake And Gearbox Woes
Hi all. Firstly, my missus has been complaining that the brake pedal on her 71 sometimes goes almost to the floor then the next time its nice and firm, any ideas?.
Secondly, the auto in this thing nearly takes your head off when it changes into second gear. Is this normal? it would be ok if it was worked but it is dead stock. :)
Any ideas would be appreciated.
don't know about the brakes, but my volvo does the same thing when changing gears, vrrrmmmmm ca CLUNK *neck snap, continue driving* probably just getting old
Edited by Jason
what about fluids? my mates old sklyline did the same thing with the auto, itd stick then snap into gear, we topped up his fluids and it was a bit better
Brake master cylinder probably needs new seals. Have the same thing in my KE10.
Check the tranny fluid level, most likely it needs a top up of fluid or just replace all the fluid.
I replaced the fluids in the auto less than 3 months ago and it was still doing it. I'd say its just rooted. I will send it to a brake specialist to get checked out i guess.
eventually, transmissions wear out, its just life. Sometimes a band adjustment can help, or it may just need a new valve body. As for your brakes, if you block off all your lines at each wheel with a set of clamps, and the pedal still goes to the floor(with fluid topped up) then the master is most likely done for. If not, remove a clamp from one corner(brake line) and pump the pedal. note any loss of pressure. Repeat on all the other lines. Then replace the clamp, and you should be able to find out where your loss of pressure is coming from.
Edited by Rollaboy2608
My mate had a similar problem with his brakes on his ra40. It ended up being tiny holes all through his brake lines. He originally didnt know what was up so he took it to the brake specialist and they checked it out. So that would be your best bet.
Good luck with it mate
Thanks guys, appreciate your input. I'm gunna have to source another gearbox i guess, as for the brakes ill send it to a brake specialist as previously stated. cheers.
