November 26, 200718 yr comment_211490 Hello everyone! Kind of new to this. have read threads but nothing seems to be able to help me. I have a 1980 KE55. currently installing sound system. I already have a themo fan and keyles entry, cd player 4 speakers and 1amp putting in 2subs and another amp soon. I wish to know if it is going to be necessary to upgrade the alternator?? Also does anyone know what alternators would fit?? Or does anyone know the cost of getting one rebuilt to 70 amps?? Any help would be great! Cheers, Luc Report
November 26, 200718 yr comment_211500 It will help. Cost me $200 to get mine rebuilt to 90-95 amps but it was around 70 stock. Report
November 26, 200718 yr Author comment_211505 It will help. Cost me $200 to get mine rebuilt to 90-95 amps but it was around 70 stock. I read somwhere on this site that a KE corolla's electrical wiring is only good to 72amps? Does your alternator kepp up with demand? Report
November 26, 200718 yr comment_211507 Mine was in a ae82 so it was abit newer, Kept up with my old type S subs well. Report
November 26, 200718 yr Author comment_211510 Mine was in a ae82 so it was abit newer, Kept up with my old type S subs well. Well evan now with only one amp.... at night the charge ligth comes on.... only dim but when a second amp goes in i'm expecting it to get brighter. Cheers anyway Report
November 26, 200718 yr comment_211515 Well evan now with only one amp.... at night the charge ligth comes on.... only dimbut when a second amp goes in i'm expecting it to get brighter. Cheers anyway the std alternator should be fine. the dull light is sometimes caused by a bad connection, try cleaning the battery terminals first and test again. sometimes caused by corrosion between the two alloy housings and the stator of the alternator. Edited November 26, 200718 yr by KE30_KE35_KE55 Report
November 26, 200718 yr Author comment_211518 That is sometimes caused by a bad connection, try cleaning the battery terminals first and test again. hey, cheers for posting, i overhauled the engine.... and every thing else so the connections are fine.... so yeah the amps (as far as i know) will be drawing more power than the alternator will be putting back in. This is from factory specs! they are rated at 50ish amps. sooooooo :P Report
November 26, 200718 yr comment_211525 hey, cheers for posting,i overhauled the engine.... and every thing else so the connections are fine.... so yeah the amps (as far as i know) will be drawing more power than the alternator will be putting back in. This is from factory specs! they are rated at 50ish amps. sooooooo :P If this a 4ac engine with Bosch alternator . My 4ac seca had a 80 amp alternator fitted so you should be able to find one easy at any wrecker. if not they can be rebuilt very easy by fitting the stator and rotor from a larger capacity Bosch alternator into your housings. late Ke55 also ran bosch alternators for the australian content to save on import tax.. Edited November 26, 200718 yr by KE30_KE35_KE55 Report
November 26, 200718 yr Author comment_211527 If this a 4ac engine with Bosch alternator . My 4ac seca had a 80 amp alternator fitted so you should be able to find one easy at any wrecker. if not they can be rebuilt very easy by fitting the stator and rotor from a larger capacity Bosch alternator into your housings.late Ke55 also ran bosch alternators for the australian content to save on import tax.. Cheers in my first post i said i had a KE55 so yeah the motor is a 4k. Report
November 26, 200718 yr comment_211550 Talk to an auto electrician. He will answer your questions and not charge you a cent. Report
