December 12, 200718 yr comment_214564 I gotta either make or buy an oil catch can for my KE10. I've been looking at a few and i've noticed some have an outlet/inlet at the bottom and two at the top. Could anyone explain where the 3 pipes would go? Thank you Edited December 12, 200718 yr by projectKE10 Report
December 12, 200718 yr comment_214565 mine has two at the top only and a drain at the bottom. one at the top goes to the PCV outet and the other goes to a small filter in the CAI box. Report
December 12, 200718 yr comment_214588 yep, cold air induction. had to box off the pod filter with the oil catch can filter to pass engineering. Report
December 12, 200718 yr comment_214592 the bottom outlet is desighned to drain to the sump i think, some have it some don't, it can just be blocked off, it easler this way anyway Report
December 12, 200718 yr Author comment_214607 yep, cold air induction. had to box off the pod filter with the oil catch can filter to pass engineering. Ah true, I only got a 4K though so i only got the air fillter on the carby. I'll have to do that when i put the 4age in though (but that wont be for a while though. Report
December 12, 200718 yr Author comment_214610 the bottom outlet is desighned to drain to the sump i think, some have it some don't, it can just be blocked off, it easler this way anyway :P Yeah thats what i was kinda thinking, but would i be right to say that it would be better to keep the oil that is caught out of the sump due to contaminants from blow-by etc. or would it not matter? Report
