November 23, 200421 yr comment_24534 I have just bought a new corolla that has been partly (so they say, I would have no idea) lowered and it keeps scrubbing only on the drivers side tyre even when there is other people in the car, and its starting to cut up my tyre pretty bad. It has 17" rims on it and i have been told that its possible that the wheels may be way to big for the actual car?? But I was thinking of just undoing the 'damge' (in my opinion) and putting regular suspension back on it. Just wondering if its worth it or not, or is there something else i can do?? :sad: Report
November 23, 200421 yr comment_24536 scrubbings just part of having a lowered car and big rims. You could try getting the guards rolled or "massaged" depending on where its scrubbing. Head to a tyre place and get them to have a look at it. They are usually willing to help and give some free advice. Report
November 23, 200421 yr comment_24543 Wheel offset could also be a problem. I'd say the easiest solution would be to see where it's scrubbing, and then rolling the guards to suit. Report
November 23, 200421 yr Author comment_24546 Nick: Its cutting the tyres up pretty bad! Well one of them anyway Demuire: if i roll the guards that stops the cutting?? Report
November 23, 200421 yr comment_24548 rolling your guards will give the tyres more clearance under there. But that depends on where theyre rubbing. I assume its on the outside. Report
November 23, 200421 yr comment_24551 Shamry: Like Ben said, it depends on what is actually hitting. Usually the problem is the rim is offset too far to the outside (or too wide), and as a result the outside edge of the tyre rubs against the inside edge of the guard. My Lancer GSR used to do that to the back tyres. If it is only rubbing a little, you might be able to get away with just bending the inside face of the wheel arch upwards to make it flush against the outside face. That way, it still looks the same from outside, and you don't risk cracking the paint (except on the actual edge of the arch, which isn't really visible anyway. Make sure you repaint the crack though to stop rust). If it's rubbing fairly badly, then you'll probably have to properly roll the guards outwards, that will give you more clearance between the tyre and guard. One other thing you could try is maybe get a wheel alignment. However, I doubt this would fix your problem unless there are problems with your alignment, or if you have adjustable camber (either via pins or tops) Raising your car won't achieve all that much. It will lessen the frequency of your tyre hitting your guard, but when your springs compress (big bump, big people in car, etc) it will still hit. Best to fix the actual clearance issues. Report
November 23, 200421 yr comment_24552 Just re-read what I typed, and hmm, wow. If you need further explanation let me know and I'll try to explain that again. If you're lucky I might even be able to use pictures :insane: Report
November 23, 200421 yr Author comment_24557 Thanks Fook! I reckon if i roll the guards outwards that will help it alot :insane: Report
November 23, 200421 yr comment_24558 You can bring it around and I'll have a quick look for you if you like. I'm in Aspley, and Nick has my number. Cheers R Report
November 23, 200421 yr Author comment_24559 That would be fantastic! Thankyou so much! Just let me know when you have a spare min, any day suits me Thankyou so much, that has blown me away.. :insane: Report
November 23, 200421 yr comment_24564 Hmm, should return slide hammer. Then again, using slide hammer to roll guards probably isn't the best idea... Would definately get more clearance, but no... :insane: Should still return slide hammer, and magazine! I am so slack :jason: Report
November 23, 200421 yr Author comment_24565 I didn't know u were offering Fook! :sad: what does a slide hammer do? Report
November 23, 200421 yr comment_24567 Heh, no... I borrowed Rob's slide hammer awhile ago to get the axles out of my diff. Have since finished with it (for now), but have not returned it, because I am slack. Slide hammers are like hammers, except you use them to pull things out (as opposed to push things in like hammers do). So yes, you *could* use a slide hammer to pull your front guards out for more clearance, but the end result most definately wouldn't be very pretty. Edited November 23, 200421 yr by demuire Report
November 23, 200421 yr Author comment_24568 lol wont be pretty either way i reckon! damn lowering of cars, load of crap.. I'm getting so annoyed with it :dry: Report
November 23, 200421 yr comment_24569 I know, you should do what I'm doing - I'm getting my car raised about 2 inches :insane: Report
