November 28, 200421 yr comment_24900 Hey all i need to know if a T series drum to drum Diff and tail shaft (from T18) will bolt up-to the Ae71 / Sprinter's under body and T50 Gear box without any major problems. Thanks :insane: ! Ted Report
November 28, 200421 yr comment_24901 Ask Mumblezz, I believe he did this conversion. AFAIK you'll need to get the T18 tailshaft as well, it's shorter than the AE71/86 one because the diff is longer. Tailshaft should go straight onto the T50. Report
November 28, 200421 yr Author comment_24904 thanks for that fook - ill try and get onto paul :insane: Cheers Report
November 28, 200421 yr Author comment_24934 if so, i forgot. Talked to paul - yup it all bolts up. :insane: Report
November 28, 200421 yr comment_24945 I forgot to add. You will need to use the front half of the AE71 tailshaft and the rear half of the T-18 tailshaft for it to fit properly. Report
