March 26, 200818 yr comment_235426 i put a new horn button in the car today and decided to test all the lights etc. flip down the indicator - the hazards come on, the instrument cluster and air con lights flash with them. this happens left and right turn the hazards on - the instrument cluster and air con lights flash with them turn headlights on - when trying to indicate either way the indicator freezes when lit up and wont flash, this is on highs and lows when high beam is on - the blu light wont come on 2 let me kno the highs are on Report
March 26, 200818 yr comment_235443 Bad earth perhaps? I'd check your battery connections first and go from there.. Kind of a tricky one to diagnose over the internet, You may end up having to pay an auto sparky to look at it for you.. Report
March 26, 200818 yr comment_235484 have you looked at the horn button installation? chances are if it all worked sweet before you installed it, the problem may be an earthing issue with the horn. Report
March 27, 200818 yr Author comment_235661 yeah well i have only the slightest knowledge on electrics and this is way outta my league. will most likely end up payin a sparky here in town. nuh cause i disconnected the horn after aswell and it was still doin the same shit. i had a wire hangin out the middle of the steerin wheel that i connected it with so i wasnt takin of stock wheel etc etc... thanks Report
April 13, 200818 yr comment_239099 why did you change your horn button? have you checked your high beam globe? have you checked your relays? Report
April 13, 200818 yr Author comment_239218 why did you change your horn button? have you checked your high beam globe? have you checked your relays? well i bought a sports steering wheel and didnt have a horn button so i got one off a mate. high beam globe is fine, all brand new headlights, but they r not on car no havent checked relays for some wierd bloody reason all electrics r back to normal now!! WTF!!?? Report
