January 5, 200521 yr comment_26829 Hey guy's, I was just wondering if there is anything I can do myself to my 4A MT Engine ? It's the FWD engine's for 1989 1.6L Twin Cam Corolla's and Nova's. Any Ideas or advice on how to keep under the hood clean and running at optimum performence, or anything else would be great. Report
January 5, 200521 yr Author comment_26831 Oh and also......it's a 16V 1.6L Twin Cam FWD 4A MT Carbi Fed Engine :thumbsup: Report
January 5, 200521 yr comment_26832 new air cleaner really helps in performence and fuel econamy good oil and fresh also helps a lot keep it clean ie wash is once a month or so and your mechanic will thank you or you wont get as dirty working on it and replace parts that need to be replaced as for more performence a set of ractors and exhaust will help mabey a free flowing air clean (holley type one) any more then that and ull start using more fuel othrwise put a 4agze or a 20v motor in will help as well should just bolt in with a a same model front cut wire and everything will work with out mods mark Report
January 5, 200521 yr comment_26838 never heard of a carby fed 16v 4A.........do they exist :thumbsup: Report
January 5, 200521 yr comment_26841 maybe its single point injection...it look a little like a carb but has 2 injectors in it Report
