2lucid Posted April 22, 2008 Report Posted April 22, 2008 this is probaly a stupid question but are 3K and 4K camshafts the same? as in will a 3k cam fit in a 4K? Quote
camerondownunder88 Posted April 22, 2008 Report Posted April 22, 2008 Depends some 3K have a different cam to 4K's some are same Be specific 3k-c,3k-h,3k,3k-b etc Cameron Quote
Felix Posted April 22, 2008 Report Posted April 22, 2008 Yes a 3k cam will fit in a 4k.... Unless the 4k is a dished piston motor, which run a narrower rear cam journal, so the cam would hit on the welschplug at the rear of the block. Quote
camerondownunder88 Posted April 22, 2008 Report Posted April 22, 2008 ^^ Really...going out to shed tomorrow to see if I can measure that...never noticed that. Well earn every day. lucky I didn't throw that 4K-e out to you..lol Cameron Quote
Felix Posted April 22, 2008 Report Posted April 22, 2008 :hmm: Yep, 5k's also have a similar setup with the narrow rear cam journal. I think you can just remove the welschplug and replace with an earlier one to be able to run the more common cams with the wider rear journal. Quote
camerondownunder88 Posted April 22, 2008 Report Posted April 22, 2008 Sweet jsut removed all welsch plugs from 5K so ill look into this :hmm: Quote
Redwarf Posted April 22, 2008 Report Posted April 22, 2008 Yes a 3k cam will fit in a 4k.... Unless the 4k is a dished piston motor, which run a narrower rear cam journal, so the cam would hit on the welschplug at the rear of the block. Even I knew that!! Having said that I only found out the last time this same question was asked.... :hmm: Quote
rawKe20! Posted April 22, 2008 Report Posted April 22, 2008 hey is this levi or his older bro either way hows it going ? i went to school with both of you. Quote
