LittleRedSpirit Posted June 18, 2008 Report Share Posted June 18, 2008 Has someone updated the Rollaclub 1/4 mile list? This is surely the quickest ke70 on there. Well done. Quote Link to comment Share on other sites More sharing options...
GOODY Posted June 19, 2008 Author Report Share Posted June 19, 2008 Thanks mate, I think I did PM someone a little while back about getting on that list but I'm not sure if I was added? Quote Link to comment Share on other sites More sharing options...
hilton Posted June 19, 2008 Report Share Posted June 19, 2008 hey dude!! got my motor in aye, just doing fucl systems and wireing atm and just waiting on cash for a tailshaft aye. hows yours going dude? you running a sr or rb box man? Quote Link to comment Share on other sites More sharing options...
GOODY Posted June 19, 2008 Author Report Share Posted June 19, 2008 Sounds like your alomst done! Tailshaft cost me either 250 or 350 I can't really remembr.. You going for a 1 piece of 2 piece? I'm using the SR box and it just clears the handbrake in 4th/reverse once you turn the shifter around. What box you going for? Quote Link to comment Share on other sites More sharing options...
hilton Posted June 20, 2008 Report Share Posted June 20, 2008 got an rb20 box man, so ill only have to trim the origonal hole. have you got any pics of your shifter and liek where its positioned??? yea probly going 1 piece man, what diff you running?? don't you have a hilux? where did you go to get ur tailshaft dude?? Quote Link to comment Share on other sites More sharing options...
GOODY Posted June 22, 2008 Author Report Share Posted June 22, 2008 got an rb20 box man, so ill only have to trim the origonal hole. have you got any pics of your shifter and liek where its positioned??? yea probly going 1 piece man, what diff you running?? don't you have a hilux? where did you go to get ur tailshaft dude?? Ahh yeh RB box should be good then, heres some pics of mine to give you a rough idea. But if your goin with that box then I doubt you will have any clearance issues. I was originally going a 1 piece but when you have a look it doesn't really give a whole lot of clearance in the tunnel so I went with a 2 piece. I got mine made at Petron Automotive in Tradelink drive Browns Plains, He usually charges $250-$350. I'm running a hilux aswell, what diff you gonna go with? I didn't need to get mine cut down because it was pretty much the same width. The stud pattern had to be re-drilled aswell as some cables made up etc. Quote Link to comment Share on other sites More sharing options...
corey70 Posted January 20, 2009 Report Share Posted January 20, 2009 hey mate, is that a silvia cross member redrilled to fit or did you cut and re-weld mounts onto the ke crossmember? Was there much tunnel work needed to be done? also with the gear stick, i thought it had to be re-cut abit further back? I'm about to tackle a sr conversion in my ke70 so info would be great. cheers Quote Link to comment Share on other sites More sharing options...
GOODY Posted February 28, 2009 Author Report Share Posted February 28, 2009 hey mate, is that a silvia cross member redrilled to fit or did you cut and re-weld mounts onto the ke crossmember?Was there much tunnel work needed to be done? also with the gear stick, i thought it had to be re-cut abit further back? I'm about to tackle a sr conversion in my ke70 so info would be great. cheers Na I'm still using the ke70 crossmember with the old mounts grinded off and new ones made up from scratch. But I have heard of people using a s13/180sx crossmember aswell. Tunnel needed a bit of bashing but if I was to do this again I would cut and extend the firewall/tunnel to make it easier for gearbox/clutch changes. The gearstick does sit a bit back from where it used to be but I reversed the shifter which gives it a bit more room. Only just clears the handbrake where it's at now but it's no worry to me really. Any more questions feel free to ask :dance: Quote Link to comment Share on other sites More sharing options...
Roo Posted March 1, 2009 Report Share Posted March 1, 2009 does it do wheel stands? Quote Link to comment Share on other sites More sharing options...
GOODY Posted March 9, 2009 Author Report Share Posted March 9, 2009 I wish lol. I had a mate watching when I went to Willobank and he reckons it just barely lifted the left wheel off the line with slicks on but I dunno for sure Quote Link to comment Share on other sites More sharing options...
GOODY Posted September 29, 2009 Author Report Share Posted September 29, 2009 Haven't updated for a while so thought I might throw some recent pics up. Also added the following, -HSD weld on coilover kit,trd yellows,7kg springs with helper -XXR 513 15 x 8 -0 rims all round -Rear guards slight flare -Rear strut brace -4.1 MIG locker -Adjustable panhard bar Thanks to "ke70Dave" for the pics aswell as a few people from the SD forums!! Quote Link to comment Share on other sites More sharing options...
36panvan Posted September 30, 2009 Report Share Posted September 30, 2009 Congratulations dude, this thing makes stupid power love it :P have you managed to improve your previous 1/4 mile time? Quote Link to comment Share on other sites More sharing options...
GOODY Posted September 30, 2009 Author Report Share Posted September 30, 2009 Thanks mate :P I haven't been back out to the drags yet, more focused on getting a bit more skilled at drifting Quote Link to comment Share on other sites More sharing options...
Roo Posted September 30, 2009 Report Share Posted September 30, 2009 your tyre is flat looks hot Quote Link to comment Share on other sites More sharing options...
GOODY Posted September 30, 2009 Author Report Share Posted September 30, 2009 Lol yeh happened after going into the dirt HARD, had a few sets so all was good. Quote Link to comment Share on other sites More sharing options...
