Looking at getting my KE25 calipers rebuilt.
I wanna keep my 12" rims now lol so I can't upgrade to ke55 brakes as they need 13" wheels.
They are seized I assume they would need a rebuild kit thrown at them.
So if anyone could recommend a good brake specialists that would be great.
Tally
Edited by Tally
  • Replies 35
Power Brakes SA
206 The Parade Norwood
ph: (08) 8332 4988
312 Mount Barker Rd Aldgate
ph: (08) 8339 4433
613 North East Rd Gilles Plain
ph: (08) 8261 0888
I would do it man just like I have done everything else on my car but as other people have said, id rather get a specialist to do it right.
And well, they are they only thing that makes your car stop.
don't want them failing when you need them the most ;)
If you've ever seen a caliper in bits they are extremely simple!
an inner seal and a boot! thats it!as long as where the inner seal is perfectly clean you'll be fine!
i had a brake specialist show me how to do it! he did one.. i did the other.
you use brake fluid and rubber grease mixed together to get the piston to slide in easier.
i haven't used the brakes but the specialist watched me do my other one and he said it would be fine!
save a bit of money and also have the experience to know you can do it!
I'd pick sprints out of all of those and make sure its a PBR-brand rebuild kit.
I wouldnt trust anything else really.
Just got back from getting them checked out.
Getting em done by my dads mate.
He said rebuild kits are available no probs but he said to cross my finders about the pistons. He called 20 suppliers and only one said he thinks he has some, and he is in sydney. So fingers crossed.
PBR no longer make the pistons anymore.
The caliper is a japanese brand Sumitomo. PS type (small =O= looking piston body, open disc pad tops with large pad protector)
My other KE20 brakes are the F type (small round piston body, closed disc pad cover with viewing hole) and thats probebly why they didnt fit, well they did but they rubbed the rotors. Rotors must be different between KE20 and KE25.
So yea hopefully it works out.
He is gonna soak em over night and then pull em apart. He said he 'MIGHT' be able to use the pistons again but its very unlikely as they would most likely be pitted from rusting.
Ill see what happens.
Tally
Edited by Tally
Well just went up to Power Brakes.
He can get the pistons and rebuild kits, and much cheaper then the other places that I got quotes from
$54 for each piston and $16 for each rebuild kit.
So Most likely get the stuff from him.
