5k
hey all i have purchesed a ke35 and have built a 5k engine for it sshould i run it in with the standard 5k carb or will the webbers do the trick
thanks mate and will a ke70 5 speed a shaft fit straigt in into a ke35?
You'll have to use the ke35 tailshaft, which will fit the ke70 box.
You'll also have to cut a hole further back in the trans tunnel to accomodate the new shifter position. :dance:
thanks mate also will ke55 front calipers fit straight onto ke25 struts and would a need a booster to make them operate because the ke25 doesnt have 1?
You'll need KE30/55 backing plates and KE55 rotors and probably hubs too. Its been covered before more than a few times.
I'm lost. Do you have a KE35 or KE25?? At the start of the thread it was a 35 and now a 25?? **Scratches head**
yeah soz mate i have two a ke35 and a ke25 I'm building my ke25 and i have biult a 5k for it and i want to throw it in the ke35 to get it run in so its ready for the ke25...the last thing i want is to have to pull it bak out out and scratch the engine bay
