August 22, 200818 yr comment_269715 I was just looking at a brand new radiator for an Ae86 on ebay and was wondering if that would be suitable for the Ke35 to run a 4age? The outlets for the water look to both be on the same side as each other Any help is appreciated Cheers - Andrew :jamie: Report
August 22, 200818 yr comment_269821 Not really. The AE86 rad is pretty wide. so most of your fins would be blocked by the front valance. May also run into problems physically fitting it in. I presume the ones you are looking at are twin core rather than single core like a standard AE86 rad. There would be better options. Early Hyundai excel radiators have become popular in AE86's, are narrower, twin core, available and cheap. Maybe a good option but research it first. Plenty of stuff on AE86drivingclub about these including dimensions. Report
August 24, 200818 yr comment_269989 Well if hes trying to fit it to a KE35, AE86 infos gonna be pretty fuggin useless. Report
August 24, 200818 yr Author comment_269992 I managed to find an AE71 radiator in need of a recore so that should do the trick as i've read a couple of other peoples threads and they have been successful with them Thanks for the replies Cheers - Andrew Report
August 24, 200818 yr comment_270076 Well if hes trying to fit it to a KE35, AE86 infos gonna be pretty fuggin useless. As far as I know, the dimensions of an excel radiator are the same whether they are fitted into an Excel, an AE86 or a KE35......... Also information about what sort of mounts they have maybe useful. Perhaps I'll just fug off and let him work it out for himself. Report
August 24, 200818 yr comment_270082 if you can use the same outlets as your stock one, get a replacement stock one or recore the original with 3 core for perfromance. else if outlets are different get an alloy one made up to suit. Report
August 24, 200818 yr Author comment_270086 if you can use the same outlets as your stock one, get a replacement stock one or recore the original with 3 core for perfromance. else if outlets are different get an alloy one made up to suit. All the 4a ones i have seen have the outlets on the same side so i guess i should get one like that But yeah i think the general consensus is the more cores the merrier :no2: Report
