Yes I have experience with 2TG's.
Have you had it on a dyno? How fresh is it? New plugs? Decent spark? Timing? Carbies in good nick or are you running efi?
I have a carbed 2TG and I'd back it against a 4AG on most days.
Edited by Redwarf
It a fresh import engine from SSS, seems good, Its running standard efi with the air flow meter, which has a really small inlet, whats up with that. I'm thinking of taking off the efi and putting carbs on it..
What do you think..
What do you think..
Get it dyno'd. I don't know what adjustments (if any) are available. If you're still not happy:
Lose the EFI, put twins on it, and don't forget that it'll have to be dyno'd again.
or keep the efi, bolt a 3tg turbo manifold on it and go forced induction.
i had a simialr setup in mine with a dead stock engine, EMS computer, small subaru turbo, 8psi and it made 123hp/ 92kw at the wheels.
weigh up your options first.
it all comes down to how deep your pockets are.
justin
