August 28, 200818 yr comment_270933 Hello guys and girls. Newbie here looking for some info on putting a small turbo on 4A-FE engine. Firstly has it been done before? and secondly can it be done?... I was also thinking bout an engine coversion later on. BUT what i was thinking was to use a turbo and manifold off a turbo starlet or something that would match the 4A-FE head and upgrading the fuel system slightly. Is there an injector upgrade for this engine? Also would it be worth remapping the ECU? I'm not looking for huge numbers here just a bit more power and torque so i can have some fun with it. Any info would be much appreciated. thanks Report
August 28, 200818 yr comment_270947 Hello guys and girls. Newbie here looking for some info on putting a small turbo on 4A-FE engine. Firstly has it been done before? and secondly can it be done?... I was also thinking bout an engine coversion later on. BUT what i was thinking was to use a turbo and manifold off a turbo starlet or something that would match the 4A-FE head and upgrading the fuel system slightly. Is there an injector upgrade for this engine? Also would it be worth remapping the ECU? I'm not looking for huge numbers here just a bit more power and torque so i can have some fun with it. Any info would be much appreciated. thanks This bloke has one in his pano http://www.rollaclub.com/board/?showtopic=22174 Report
August 28, 200818 yr comment_270957 Toyota starlets don't run a 4A motor, they've got a 4EFTE, so the manifolds won't be any good. Toyota ecu's can't be remapped, you'll need to go to a stand alone unit, or a piggy back. It might be worth looking into a 4AGZE swap if you want decent torque, that way you can use a factory ecu for the job. Report
August 28, 200818 yr comment_270963 Go and join http://www.celicatech.com/forums/index.php. They have the best info I've seen on turboing 4afe's. Report
August 28, 200818 yr comment_270975 if your talking about the later model of 4afe then you could bolt on all the turbo bits off a 7afe turbo engine, getting those parts would be almost impossible though I would think seeing how few where made. Report
August 28, 200818 yr Author comment_270987 so maybe an engine conversion is the way to go! Has anyone heard of a 4A-FE engine being turbo'd? Edited August 28, 200818 yr by legless Report
August 28, 200818 yr comment_270994 why would you want to turbo a fwd corolla :sob: if you want more power 4age or 4agze straight bolt in I'm assuming being an ae92 Report
August 28, 200818 yr Author comment_270996 not a very popular idea is it! oh well back to the old drawing board. thanks for your help. Report
August 28, 200818 yr comment_271022 not trying to be rude. but 4afe isnt a great starting base. try my above post for my power from stock. Report
September 12, 200818 yr comment_274485 best answer no no no dnt do it i have one they suck I'm goin to 4age just do the conversion it will turn out cheaper trust me if u have any more questions feel free to pm me Report
