Hello guys and girls. Newbie here looking for some info on putting a small turbo on 4A-FE engine. Firstly has it been done before? and secondly can it be done?... I was also thinking bout an engine coversion later on.
BUT what i was thinking was to use a turbo and manifold off a turbo starlet or something that would match the 4A-FE head and upgrading the fuel system slightly. Is there an injector upgrade for this engine? Also would it be worth remapping the ECU?
I'm not looking for huge numbers here just a bit more power and torque so i can have some fun with it. Any info would be much appreciated.
thanks
thanks
This bloke has one in his pano
http://www.rollaclub.com/board/?showtopic=22174
Toyota starlets don't run a 4A motor, they've got a 4EFTE, so the manifolds won't be any good. Toyota ecu's can't be remapped, you'll need to go to a stand alone unit, or a piggy back.
It might be worth looking into a 4AGZE swap if you want decent torque, that way you can use a factory ecu for the job.
if your talking about the later model of 4afe then you could bolt on all the turbo bits off a 7afe turbo engine, getting those parts would be almost impossible though I would think seeing how few where made.
best answer no no no dnt do it i have one they suck I'm goin to 4age just do the conversion it will turn out cheaper trust me if u have any more questions feel free to pm me
