Static Compression
static compression is swept volume + compressed volume devided by compressed volume. the only variable on this is valve opening and timing Eg the wilder the cams the more compression (boost) timing, you can use, if your engine detonates it won,t matter if you have pistons or not, good ones may last a bit longer but not much, atomic speedware have a arias piston pauter rod kit for$1172 us $1500 landed
  • Replies 30
  • Views 8.1k
