4k Not Running Right After Mechanic Does A Service On It
  • Replies 43
  • Views 11.7k
ok well i put in the elec dizzy today, got it all good, the mechanics apprentice helped me with it
she runs beautifully
changed the clearances to those reconmended and no way it was way too loud, and the idle went higher, or sounded like it did
also with tach after putting in elec dizzy and high energy coil and ignitor the tacho jumps everywhere except after about 3000 rpm
how can i fix that? is it because i took off the ballast resistor?
Travis
Travis
You can install a variable ohm resister inline to the tacho signal from the coil which helps steady the needle, Autometer recommends it with their tacho's if it is unstable.
ahh ok, how do i get one and where?
cheers
o and its not an aftermarket tacho
Jaycar electronics or Dicksmith
is there a certain one i have to get?
can get it today as i will be near dicksmith so do tell!!
Used to have this problem a long time ago. Was points being too close together and spark jumping. Electronic dizzies still have something to adjust called an "air gap" on the magnetic pickup, try opening this up just slightly and see if the tacho get any better befor you head off to DS. :jamie:
i wouldnt know where he air gap is
mechanic would know right?
Yes mechanic will know. Just thought it might be worth a try befor finding/fitting a resistor.
If you pull you dizzy cap off, you notice the is a little magnet that lines up with the 4x tags on the main shaft. the gap between these tags and the little magnet I speak of is the "air gap". You adjust it just like points.
I had a similar problem once with a electronic distributer I fitted a condenser to the negative side of the coil and it fixed the problem.
a condenser aye, well how about the lil grey box connected to the red wire that came off the pos side i originally had on points dizzy, i heard its a condenser
would that work?
would that work?
woth a try. it worked for me
so you used the original one off the points dizzy?
