SLW42 Posted December 19, 2008 Report Share Posted December 19, 2008 does anyone know were i can get better cams for a 4age in qld :y: i am aiming to make mine rev to about 9 and a half :) Quote Link to comment Share on other sites More sharing options...
Redwarf Posted December 19, 2008 Report Share Posted December 19, 2008 Tighe Cams. Personally I wouldn't build another engine to rev that high. They're a bit pointless. I know the 4AG will do it, but you really sacrifice anything down low, which makes it hard to drive on the road, and believe it or not, on the track, unless you're a serious peddler with clairvoyant gear selection. Quote Link to comment Share on other sites More sharing options...
SLW42 Posted December 19, 2008 Author Report Share Posted December 19, 2008 i am hopin to get it out that far but with a turbo hopin keyword Quote Link to comment Share on other sites More sharing options...
Redwarf Posted December 19, 2008 Report Share Posted December 19, 2008 In that case with a turbo it would be pointless. Quote Link to comment Share on other sites More sharing options...
SLW42 Posted December 20, 2008 Author Report Share Posted December 20, 2008 what even without a turbo but high comp pistons and a ported an polished head??? Quote Link to comment Share on other sites More sharing options...
Redwarf Posted December 20, 2008 Report Share Posted December 20, 2008 If you have a cubic amount of dollars, anything is possible, but it doesn't mean that it will be practical. What do you want to use it for? Quote Link to comment Share on other sites More sharing options...
the_random_hero Posted December 21, 2008 Report Share Posted December 21, 2008 I laughed so hard when a mate of mine told me he was building a 4AGE that will redline at 11500rpm. Even if the oil pump somehow didn't blow itself to pieces (not to mention the rest of the engine), it's either going to have stopped making power at 6k or will have absolutely zero torque. Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted December 21, 2008 Report Share Posted December 21, 2008 i don't understand, revving to 11000rpm works in the cartoons, why not in real life? :lmao: Quote Link to comment Share on other sites More sharing options...
love ke70 Posted December 22, 2008 Report Share Posted December 22, 2008 it does work, check out 6boost's 1g. but thats purpose built drag. doesnt make any power til 5500. and if it were me, id be buying something like HKS or whoever else cams for these motors, all the regrind places, i wouldnt trust them to have done their research... cheers, andrew Quote Link to comment Share on other sites More sharing options...
styler Posted December 22, 2008 Report Share Posted December 22, 2008 (edited) i don't understand, revving to 11000rpm works in the cartoons, why not in real life? :bash: haha only happens if you park your panda ae86 outside a real tofu shop :y: on the subject of camshafts and turbos... bigger camshafts and high static compression ratio are a typical NA build not turbo, recently higher compression turbo builds have been made but its not really that common yet except for low boost oem or unstreetable big power builds. i would imagine the bigger the cams and bigger the turbo you go would make it very unstreetable with turbo lag combined with the camshaft power band moving way up in the rev range and the idle being turned far up. bigger camshafts have a longer duration - they open earlier and close later, so you need a high static compression ratio because the bigger cams lose more of the compression and you need the dynamic compression ratio to end up somewhere usable. thats why the bigger the cam the higher the static compression ratio, so the dynamic ratio ends up about the same generally. static compression is engine volume with piston at bottom / piston at top ( / = divide) dynamic compression ratio is the same but now with the camshaft opening and closing and letting the fuel mixture enter and escape as the piston moves up and down affecting the volumes measured. Edited December 22, 2008 by styler Quote Link to comment Share on other sites More sharing options...
