My 300hp Corolla
thx for the love guys i am doing some new work on it and will post new pic`s later but heve are the spec`s and i only did mid `3`s in a Q mile could get less if i had beter sticky tires. lol :)
engian:
turbo sx to4e-t3
turbo xs intercooler
block overbore 81 to 83 mm
blueprint and balance
4agze crank
4agze rods
cp pistons 9:1
arp bolts ,main ,head & rods
acl racing bearings
toga high volume oil pump
hks 4agze metal head gasket
head port and polish
oversize stainless steel valves of the 4agze
bronze valve guide
silvertop 4age itb`s
custom air box for itb`s
440cc rc injectors
costum cam pulley
works 1 alt. pulley
stb aluminum crank pully
sti ngk spark plugs
ngk wires
msd coil and 6al boost timing master control unit
obx radiator silicon hoses
civic 3" radiator
fal fan
hks bov ssq
hks heat shield
morosso catch can
aromotive fuel regulator
turbonetics wastegate with 10 pound spring
turbonetics velocity stack
3sgte map boost sencor
nascar oil cooler and tranny cooler with mini fans
nrg engine torque damper
  • Replies 46
  • Views 32.5k
this engine so clean well done. I can see you have spent many hours on this project.
Just the first time I did it the other 3 times I posted on the CCC site and everyone watch because CFT has a web cam.This is when the motor was firsts built and the first dyno we had a few problems that day, the timing was 180 degrees off the tps wasent reading and the MAP sensor was going crazy. all bugs fix for now just need to go stanalone for my 400 hp goal.
click on video link below
http://s120.photobucket.com/albums/o188/vi...ladynotest1.flv
Edited by pnyk33
amazing mods, two things though:
how did you adapt the valves off a 4agze when the 4afe valves a so different?
I think you might be losing a heap of airflow from your intake manifold to the cylender head, wouldnt there be a sharp step between them from the inside of the intake manifold to the angle of the inlet ports?
FAIL!!
The vid doesn't work ;)
i fixed it try again :)
they were cut and regrove to work the only difference was that the ze are longer and are`s are shorter.
I bet that would be fun to drive!! What sort of tyres are you running? Does it break traction all the time?
Robert.
new things coming for 09 Superpro bushings Whiteline sway bars
Edited by pnyk33
what about the intake manifold? I think you would be losing heaps of power through it, want me to draw a diagram?
carbon fiber gas lid to match the Hood,mirrors, trunk and headlights
i am helping my friend with his car he has a te 1.8 with turbo and standalone system at 11`s in a Q mile
here is a quick video
we wanted to do something different so we built a ITB`S set up for the motor sence no one has done a 20v set up on a 4afe motor so far so good got 300 hp out of it and alot of TQ off the line. :)
Edited by pnyk33
