January 21, 200917 yr comment_309877 Ive just been trying to install some stock fron struts in the front of my KE38 which i got fron a KE55 coupe Now what is currently in there is R31 brakes with coilovers and some unkown steering arms and i think the tie rods are different too? Would any one be able to tell me what is actually been changed so i know what to get? Once again an easy job has turned into a nightmare because of buying a previously modified car. here are some photos..... Cheers for your help in advance Report
January 21, 200917 yr comment_310063 Well ill have a crack at it.First the control arm is not standard judging by the redrilled link pin. May be corona or sigma {guess no 1} The steering arm [ from ball joint to tie rod end}is not ke or xt130,or ra40. :P Compared to what ive got here. My guess no 2 is that it could be sigma. [GUESS] :( Sorry not that helpful but I'm sure some one will be a long to put us straight. rob Report
January 21, 200917 yr comment_310068 Could be R31 steering arms. I believe they have a 10mm offset from centre..... Report
January 22, 200917 yr comment_310125 can you source the lca's and steering arms from that same ke55 you got the struts from? at least then you'll know it all works. may i ask why you're not using the r31 struts? -dave Report
January 22, 200917 yr comment_310146 gidday Matthew, I think you're in Adelaide? p'raps this will help: KE parts In amongst that lot, you'll find I'm selling off a complete KE30 front end without the struts for the mega value price of $10 (or a six pack). stock control arms stock sway bar stock tie-rod ends stock lower control arms stock radius rods stock steering arms blah blah blah basically, everything bar the struts. use what you need and chuck the rest in the shed for a rainy day, or in the bin :P cheers, Slapper Edited January 22, 200917 yr by slapper Report
