M.T Posted February 8, 2009 Report Share Posted February 8, 2009 hey guys i just bought a ke70 in really good condition Just noticed when my lights are on and i indicate left the lights switch off and then turn back on when the indicator flicks off. But the right indicator is fine the lights stay on. Also found out when u jiggle the indicator stick when indicating left the lights come back on. Does anyone know what could be the problem if you understand what i am saying. Cheers. Quote Link to comment Share on other sites More sharing options...
Monkey Wrench Posted February 8, 2009 Report Share Posted February 8, 2009 The contact in the indicator stalk will be dirty, Just try another stalk. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted February 8, 2009 Report Share Posted February 8, 2009 Sounds like the contacts in the combo switch are playing up.. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted February 9, 2009 Report Share Posted February 9, 2009 ..and its a common problem in various guises, ours turns the dash lights out but not the headlights, so expect a stalk from the wreckers to give trouble unless you're lucky! Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted February 9, 2009 Report Share Posted February 9, 2009 If you are mechanically and electrically handy, you can pull the combo switch apart and tweak the contacts to fix it. Quote Link to comment Share on other sites More sharing options...
interlopr Posted February 12, 2009 Report Share Posted February 12, 2009 try this, hope it helps. http://www.ae86drivingclub.com.au/forums/s...hread.php?t=350 Quote Link to comment Share on other sites More sharing options...
smeetsy1 Posted February 12, 2009 Report Share Posted February 12, 2009 I had that problem with my ke20. All i did was take off the steering wheel to get to the indicator mechanism, take off and clean everything inside with metho and cotton buds. Re-assemble and all better. The problem i had was 30 + years of grime in there which was not letting the mechanism contact. Hope this helps. Quote Link to comment Share on other sites More sharing options...
