What is the max psi can you got to before running into trouble :|
i want to push the limits !!!!!!
(i am running 211psi with NGK bp6eys)no probs yet ?
Why do you want to know? PSI doesn't give you compression ratio if that's what you're getting at.
MY 5K Runs ~200 PSI but the compression is about 11:1. That isn't a relationship though as the comp ratio is a Volumetric function.
OK i thought the psi was the main Table to work from ? how do you work out ratio then
Swept volume (size of motor - ie 1300cc)
= Pie r squared x stroke of motor
Engine capacity = swept volume x no of cyl
Compression ratio = (Swept volvume + Clearance volume ) divided by clearance volume
You also need to factor in things like ring land to piston crown, piston diameter, dish volume, deck clearance.
This is the list I sent my engine builder to calculate my compression ratio:
Bore Diameter: 3.248 inches
Stroke: 2.874in
Cylinders: 4
Combustion Volume: 18cc
Crown-Deck distance: -0.0118in
Piston Valve Relief: 0
Compressed Gasket Thk: 5 thou?
Gasket Bore Diameter: 3.268in
Piston Dish Volume: 8cc
Outer diameter of piston at crown: 3.177in
Piston crown to ring land distance: 0.276in
