March 10, 200917 yr comment_326461 Hi, I am having trouble chasing a set of new flexible rubber hose for my KE15 sprinter and I was thinking KE20 brake lines might fit as there the same calipers so the rest of the hose should fit. But Just to see if it will better I am chasing the part number for KE2X brake lines for the front left and right lower hose and upper hose both parts of the flexible hose so caliper to strut strut to wheel arch where it then joins the solid line. Cheers Cameron Report
March 10, 200917 yr comment_326483 ke2x hoses: FRONT WHEEL Hose L/RH 01/1971 - 12/1974 ALL BODY TYPES, SEDAN, DISC/DRUM H1164 FRONT WHEEL Hose-Chas to Bkt L/RH 01/1971 - 12/1974 ALL BODY TYPES, SEDAN, DISC/DRUM H1163 From PBR website. Report
March 10, 200917 yr comment_326486 Hi Cam Check these out. Hopefully they are what you are after. If you need any further detail, just let me know. Keep clicking on the image and it will magnify. Report
March 10, 200917 yr comment_326520 When i needed new hose for my corona I just took he old ones into my local brake shop and they made up new ones for me. They looked the same and fitted the same with out any dramas. I can't remember how much but I didn't think they were too pricy. They've been there two years with no problems. Report
