March 17, 200917 yr comment_328610 hey guys, could anyone provide specs/pics of the kinda wheel nuts that i will need to put my trx wheels on the rolla? have been to a couple of tire places, and they just scratch their heads. would rather not swap the studs out of the hubs any help would be much appreciated cheers carl Edited March 18, 200917 yr by bezender Report
March 17, 200917 yr comment_328611 hey guys, could anyone provide specs/pics of the kinda wheel nuts that i will need to put my trx wheels on the rolla? have been to a couple of tire places, and they just scratch their heads. would rather not swap the studs out of the hubs any help would be much appreciated cheers carl Just look at the hole in the wheel and find out if you need flat, shanked, rounded or chamfered wheel nuts, then get ones to suit the Corolla studs. Normal policy is if the thread size is the same then use whatever nuts came with the wheel, if the thread isn't the same size then use the same style nut but with the appropriate thread for the studs. Edited March 17, 200917 yr by Hiro Protagonist Report
March 17, 200917 yr Author comment_328621 cheers looks like I'm after shanked nuts with a bit of a taper. ill call around n get frustrated :P Report
March 18, 200917 yr Author comment_328916 any chance someone who has these wheels on their keto could take a nut off and post up some pics?? Report
March 18, 200917 yr Author comment_328936 getting custom lock nuts made for the rolla and the R32 :P my wheels are going no where Report
March 18, 200917 yr Author comment_329165 here she is :D had some blank nuts tapped for the application, apparently they are not toyota studs in the hubs :yes: pls ignore the filth on the car... I'm busy saving the murray :lol: Edited March 18, 200917 yr by bezender Report
March 18, 200917 yr comment_329242 As above, use the nuts that come standard with your wheels. Changing wheel studs is an incredibly easy job to do. I have late model sigma studs in my AE86, same thread just longer (and newer). The pickapart person didn't even charge for them. Custom nuts seems an expensive and unnecessary option. Report
March 19, 200917 yr Author comment_329358 As above, use the nuts that come standard with your wheels. Changing wheel studs is an incredibly easy job to do. I have late model sigma studs in my AE86, same thread just longer (and newer). The pickapart person didn't even charge for them. Custom nuts seems an expensive and unnecessary option. the origional nuts would have been used if they fitted the rims :D the custom nuts were $30 LOL. generic nuts cost more... it's pointless swapping studs, when at a small cost I can get shiny nuts that fit perfectly ? Report
March 19, 200917 yr comment_329371 I've had TRX rims on my corollas for years, including on my KE36 just like yours, and have always used the stock corolla wheel nuts. They fit perfectly and have never had a wheel come loose/off, nor done any damage Report
March 20, 200917 yr Author comment_329610 great, the fact still remains that if the nuts i had on there fitted, i would have used them. like my earlier post states, they are not toyota studs in the hubs :y: Report
March 20, 200917 yr comment_329690 The fact still remains that stock wheel nuts fit TRX rims, so whatever thread you have on your car, a stock set of wheel nuts off whatever car shares that thread pattern would have worked. Edited March 20, 200917 yr by Rolla__Boy Report
March 20, 200917 yr comment_329692 And if they are not toyota studs....what wheel nuts did you have on it before? Report
March 20, 200917 yr Author comment_329696 bit of background first of all, i have had the car for about 3 months, only things i have changed on it is the fuel pump, and dropped a weber in... I'm not too sure yet what previous back yard mechanics have done to it As for my choice of nuts. trx rims should really have shanked nuts on them (i went for this option, not only because they are what the trx's had on them, but also cos it will be a lil while before i get hubcentric rings in to take the load off the studs, and get it on the hub). the nuts that i had on the stockies were all miss matched and as they arent shanked they could not get enough purchase on the studs for my liking. i don't fancy loosing a wheel while driving :y: i took one of the nuts in, and they matched up the thread to one of the studs that they had lying around. pretty sure they guy said it was common on fords, not 100% sure what he said though, the dude was mumbling, and i was distracted by a nice cefiro in the carpark Report
