Brake Noise
Hey guys, lately my brakes have been making a noise whenever they're on, even just slightly and I turn the steering wheel.
Its a similar noise to when the brakes are dusty but its only when I turn a corner before I take my foot off completely.
I'm about 90% sure the brakes aren't worn yet, and I think if they were dusty it would happen all the time...
Anyone have any ideas?
Thanks, Lexxi
could be your brake pad wear indicator??
is it a high pitch metal noise??
Agreed^^ I've been havin the same problem over the last month or so. Until yesterday when there was a constant noise. Turns out one of my brake pads was totally worn on the right hand side. Now I've replaced the brake pads but the noise is still there. So today I've ordered new rotars and a caliper kit as I believe that one of my calipers is ceased.
Check your brake pads and I'd say that they would be pretty worn.
But they had like 75% left when I started actually driving it like....... 2 months ago? Maybe 3?
I'll have a look when I get time, but I'm pretty sure they're not worn.
I can't tell if its high or low pitched, its kind of a howl lol
could be a seize caliper?
hose with water your calipers or disc,to get rid of brake dust?
ive seen cheap as pads wear out in less than 3 months and if your slides are siezed it could just be wearing out 1 of the pads as above
your piston may be seized causing the inside pad to stay on the rotor after your foot has come off the brake.......
and then it could also be your slides which are seized which is causing the outer pad grab.....
best thing to do is pull the calipers apart and have alook to be sure....
may have to get a caliper kit...... and do some light honing........also use alot of never seize on the slides :y:
hope this helps
luke
So what do I do if its a seized caliper and how much would it cost to get a caliper kit and stuff?
caliper kits are pretty cheap..... and if its seized you may be able to work it lose then take it apart and clean the bores of the slides and piston..
if you not very handy on the tools I'm sure the brake shop wouldnt cahrge to much>>>>maybe lol.........
if not get a workshop manual for the car and it should pretty much give you a step by step.....
I got a caliper kit today. Normal price is probably less than $20 but i got it cheaper again. It definitely seems that your havin the same problem as me.
Quick question, is it dangerous or damaging to keep driving if it is a seized caliper?
And would that make the noise only when turning?
yes its dangerous!
why you may ask?well the braking wheel with the seized caliper can lock up causing you
to hit maybe oncoming cars,traffic,pedestrian other vehicles or power poles or leak brake fluid through
faulty brake caliper weak rubber components etc.don't forget it can wear out disc rotors aswell!get fix straight away pls!
Coz I've been driving on it for a while and it hasn't affected my braking power yet. But maybe it hasn't done enough damage yet.
I'll have to fix it before the cruise then :P Good luck.
