4age Rebuild Prices
SLW42
i started a thread on the exact same thing a while ago labelled 4age reconditon
http://www.rollaclub.com/board/?showtopic=27945
bit of info there
i got pistons with rings and everything and also a complete full rebuild gasket, ring and washer set from a guy here all for $500
just so you know I'm doing a 4age conversions into ke70 and ive spent about $900 and got almost all the parts i need, spending another 300 this weekend
you should be able to rebuild your engine completely with new oil and water pumps for $1000
just a few things i'd consider if your looking to save money
can you reuse your old pistons and just buy new rings?
do you have ebay account to buy gaskets off there? you can get full set for around $500
including the washers and rings.
Edited by kiahn
Link to comment
Share on other sites
just looking thought my invoice folder
and a for new pistons, rings, bearings, thrust bearings, welsh plugs, conrod gudgen pins re-bushed, bored ,surface grind, polished crank and acid dipped
was a grand total of $828
and thats using all acl pistons and bearings
and i always use a genuine toyota head gasket :wink: ;)
Link to comment
Hey Just a heads up fellas, I just went through the same business of High 4age price's.
Spoke to a fella I get my chev parts from in the states.
Orderd parts threw him heaps heaps cheaper.
He has a wholesale import/export company over there!!
I Can get Full Bearing set and Full Gasket set
Main/Rod/Thrust Bearings These come in a box NAKAMOTO.
But are ACL bearings distributed by this company.
ACL is stamped on the bearing!!!!!!!!
Full gasket kit is great All main gaskets, plus crank and oil pump seal, Cam seals, Valve stem seals,
Small and Big port inlet, Sump gasket Everything!!!!!!
Can do $215 the lot plus Oz shipping only.
Will get photo's if every1 interested.
If I didnt get my pistons already I would have got a full kit,
PISTONS, RINGS, BEARINGS, FULL GASKET SET, OIL PUMP, WATER PUMP.
OIL FILTER, TIMING BELT. $550 p/ oz ship.
All Available sep. I ordered from him Thursday last week arrived Monday arvo :party:
PM if interested. Just letting everyone know cause my Oz quotes were
Pistons $280, Bearings M$95/R$75/T$26, Full Gas set $195, Oil pump $80(trade price), Water pump $65, Belt$45 Etc Etc
  • Upvote 1
Link to comment
