I have the standard k series radiator in my car with the 2tg and as the picture below shows the hose doesn't have the bend to fit on. As I see it I have 2 options
1. find a hose with that 90 degree bend in it - any ideas on that one?
2. Get a piece of metal pipe to fit between the hose I have and another hose that is a 90 degree bend...
Any help on this?
as you already know just did my conversion and i did what red did... get the inlet moved to the other side. only took half a day for the rad shop to do it.
if you want to go down the cheaper way or get a ta22 radiator bud that might work to and it should fit aswell
I rang a radiator place and changing the outlet over is not much hassle.
My perhaps stupid question is, with both outlets on the same side of the radiator wont it make it pretty inefficient?
The coolant is still going to get pushed through the radiator by the water pump, so I can't see it being a big issue for cooling. Radiator place would know best though.
They put a little deflectory do-dah in there to direct the water flow in the direction required. I had it in with a good competition motor, and never had any issues. (It was a three core.)
Out of curiousity, I wonder how a flipped AE82 Twincam hose would go. Looks like this, so just mirror-image it and cut it down to the right length
it would work but i have a feeling he has been convinced on moving the outlet on the old radiator across,
IMHO you should have just found a ta22 radiator and used that
Edited by mr ae71
Yeah i have been convinced. My radiator is in good condition and I think everything will look much neater this way.
Thanks for the help, getting closer to the finish every day.
