TRD ke70 Posted May 6, 2005 Report Posted May 6, 2005 i'm researching something at the moment and i need a photo of a w55 gearbox(side on, front on). i'm hoping i'm right, if i am, w55 to k bellhousings will be easy to get. even a list of cars they came out in. Quote
kangaroosa Posted May 6, 2005 Report Posted May 6, 2005 Scroll down and there is side pic of a w55. Its sort of top/side view. There is also a bit of info on the gearbox too. http://wwwrsphysse.anu.edu.au/~amh110/supra_in_volvo.htm There is one pic here of the bellhousing. Filename is "tracing.jpg" http://locost7.info/mirror/1zzfe_adaptor.php http://www.billzilla.org/4AGE-W55.jpg Scroll down to the bottom of the page. http://www.billzilla.org/4agmods3.htm A few bellhousings for sale. http://www.reardrive.co.nz/order.asp Close-Up pics further down the page. http://64.233.179.104/search?q=cache:FfuBC...arbox+pic&hl=en http://64.233.179.104/search?q=cache:v62i5...arbox+pic&hl=en http://64.233.179.104/search?q=cache:3E3bI...arbox+pic&hl=en W55 alloy 5 speed manual can be found behind R and turbo T engines. Hope some of this helps :) Quote
TRD ke70 Posted May 6, 2005 Author Report Posted May 6, 2005 a big thank you for that. from the looks of that, a W-K bellhousing is in a SBV townace van. that same box comes out in hilux, hiace, townace, corona. i'll have to do some more checking to confirm it but f@$k it looks good. Quote
Nitephyre Posted May 6, 2005 Report Posted May 6, 2005 so chris, you think it IS a W box in there.... *coffdibscoff* hehe JK! :) Quote
Super Jamie Posted May 6, 2005 Report Posted May 6, 2005 be careful, some van gearboxes that bolt up to K motors are side-shifter things. i think they're called a G40 and G50. it sucks when you get a dirty old van bellhousing from the wreckers, spend ages cleaning and polishing it so it looks schmick, then it doesn't fit on your T50. and the bastard ummed and ahhed when i tried to return it too :P Quote
TRD ke70 Posted May 6, 2005 Author Report Posted May 6, 2005 the chassis code does say G510 i think but it's the bellhousing i'm interested in. the SBV is floor change, but the gearbox mount is on top of the tail housing, spose you could just change the rear housing. i have to get the motor and box out before i know for sure. what we do is take the bell housing off and just sell the box bare. so if it's the right thing bell housings should be easy to come by. i'll post it when i know for sure. fingers crossed. Quote
