May 23, 200917 yr comment_346856 hey guys i just put extractors on my 4k motor and it is not running right in high revs its great but down low its shit house of course there are some hoses that don't connect buck up to anything when you put extractors on but what hoses do need to be connected still and which ones can i get rid off just want to make it run right thanks guys its working now :D :fuzz: Edited June 8, 200917 yr by KE70PWR Report
May 23, 200917 yr comment_346859 could need a tune up, has a vacuum leak, or both get a mist squirter and spray a little water around inlet/exhaust manifold to check for leak while its running. revs die = leak did you check the inlet and extractors with a straight edge before putting them back? there was a thread about the flange of the extractors being slightly bigger than inlet flange a few days ago just a few ideas you need the distributer vac advance & charcoal canister line, check out the vacuum diagrams in the faq http://www.rollaclub.com/faq/index.php?tit..._System_Diagram Report
May 25, 200917 yr Author comment_347373 ok no leak in manifold but still can't get it to run right low revs under load its shit but high revs its cool tried adjusting the fuel mixture made it a bit better but still doing it when its cold runs good at low revs lol any help Report
May 25, 200917 yr comment_347386 What have you done with all the factory EGR gear? I reakon you've got a vaccum leak somewhere there. Did winding the mixture screw all the way out help? I'd say you've got a manifold leak of some sort. Report
May 26, 200917 yr Author comment_347671 i sprayed so much water on it its not funny and didnt react at all so no manifold leak yeah moving the mixture screw helped but didnt fix. if i pull the choke on when i take off its fine then push it in when it gets above about 2000 rpm lol Report
May 27, 200917 yr Author comment_347781 ahhhh just drove it again and its still doing it ahhhhhhhhhhhhhh f@$k Report
June 1, 200917 yr Author comment_349197 ok if i wind the mixture screw all the way in until it nearly stalls it runs better at the low revs but it still chuggs until the revs get up a little like 2000 can't find a vacum leak or gasket leak Report
June 2, 200917 yr comment_349210 Stock carb?? What vac hoses are hooked up and to where?? There aren't any hoses hooked to the exhaust manifold, so nothing on the inlet should have changed... How are the thicknesses of the manifold flanges?? Same, or are the inlet flanges thinner where the bolts go on? Edited June 2, 200917 yr by altezzaclub Report
June 2, 200917 yr Author comment_349236 stock carb all hoses still hooked up apart from the hoses that were connected to the old exhaust manifold flanges are the same i think the washers are sitting flat and no leaks sprayed water around them and nothing changes Report
June 2, 200917 yr comment_349471 OK, the only hoses on my exhaust are to do with the EGR valve thing, so I suppose all that has vanished on yours. Have you blocked the hoses that used to work the valve? They will let air into the carb... Report
June 3, 200917 yr Author comment_349487 \yeah but i just found a hose that went to the front of the manifold like a black plug that screws in and has 2 hoses coming out of it one of them has broken off is that a hose to do with emmission control or something else i blocked it off and it did not help Report
June 3, 200917 yr comment_349490 \yeah but i just found a hose that went to the front of the manifold like a black plug that screws in and has 2 hoses coming out of it one of them has broken off is that a hose to do with emmission control or something else i blocked it off and it did not help G`day mate, I had an incidence years ago where I inadvertantly over tightened the bolt that holds your air cleaner on. That tends to slightly warp the top half of your carby and it runs like puss. Worth a try. Report
June 3, 200917 yr Author comment_349496 thanks but deos the same with no filter on there and cover off Report
