love ke70 Posted June 8, 2009 Report Posted June 8, 2009 nah the line mid way up the door, looks like it sits higher than the gaurd and the rear welded in door?... Quote
trav_555 Posted June 8, 2009 Report Posted June 8, 2009 O wow I didnt know thats how the rear window looked stocked, loks weird now that I'm loking at it more. i would have preffered a larger pillar behind the door, but if your making it look stock then it will work better for you ;) Looks heaps good, get some photos up of the inside and how its welded together ;) Travis. Quote
Boost+k Posted June 9, 2009 Report Posted June 9, 2009 i got a 2dr wagon i could take some pics of if you like, you want a pic of the pillar where the catch goes? Quote
love ke70 Posted June 9, 2009 Report Posted June 9, 2009 boost+k ive got two 2 door wagons, or panelvans, as it is already, its the C pillar that I'm looking at, the angles are all different in the bottom rear corner. Quote
Mish Posted June 9, 2009 Author Report Posted June 9, 2009 i got a 2dr wagon i could take some pics of if you like, you want a pic of the pillar where the catch goes? Yeh some photos of where the latch goes on would be appreciated thanks Boost+k. I need to figure out how I'm going to make my plate look before i weld it on the inside of the door... I was thinking of just making it square to the edge of the door straiht back to the pillar.... Probably the easiest way and it will look pretty good. But if you got some photos tha migt give me some ideas... Quote
