June 23, 200917 yr comment_354312 hey just wondering what would be the best sized exhaust on a stock 4kc should i go under diff or over? and are a 38/38 webbers too big for a 4kc? thanks Report
June 23, 200917 yr comment_354320 hey just wondering what would be the best sized exhaust on a stock 4kc should i go under diff or over? 3" straight through and are a 38/38 webbers too big for a 4kc? anything smaller than a 750 holley is for pussies Nah, just pulling your leg :) :) FAQ here and use the search function HERE I probably could have spoon fed you in the time it took me to add those links, but I think it is in your best interest to do some research yourself. Report
June 23, 200917 yr comment_354345 3" straight through anything smaller than a 750 holley is for pussies Nah, just pulling your leg :) :) FAQ here and use the search function HERE I probably could have spoon fed you in the time it took me to add those links, but I think it is in your best interest to do some research yourself. i thought 4" mandrel was the minimum for maximum power? Report
June 24, 200917 yr comment_354425 i thought 4" mandrel was the minimum for maximum power? Only if you feed you 4k with TWIN 750 double pumpers, then 4" might be a bit small. :) Report
June 24, 200917 yr comment_354546 i would have thought with a stock 4k, after reading the faq. i have been thinkin for my car a 1.75" to 2" pipe over the diff. Report
June 24, 200917 yr comment_354598 hey if you've read the faq but still can't decide: ive got a stock 4K-s with a 2 inch press bent system so the min is around 1.8" it is pretty good if you put a pod filter on the way i did(cheap yet effective), it gives a tad more power and allows for a bit of modification without being over kill for a stocko oh and if your planning on lowering your car go over diff so as to not scrape on every speedbump hope that helps Report
June 25, 200917 yr comment_354693 With most corollas you shouldn't have any real trouble going over the diff/axle, there's ample room. Although if you're on the bump stops.... Report
June 25, 200917 yr comment_354740 QUOTE-With most corollas you shouldn't have any real trouble going over the diff/axle, there's ample room. Although if you're on the bump stops.... haha bump stops... allways a problem.. when you have them Report
June 25, 200917 yr comment_354904 i would have thought with a stock 4k, after reading the faq. i have been thinkin for my car a 1.75" to 2" pipe over the diff. better for flow if you go the other way around. do some reading about exhausts on wrx's in particular the mrt exhausts. As the gas travels further from the engine it cools down thus losing energy, and slowing down, if you step the pipe down in size slightly as it gets further away the gas speed stays really fast, thus you get good scavenging. Doesn't give you any street cred though if you have a small exhaust pipe coming out the rear of the car. Being pedantic I know. Robert. Report
