Interferance And Non Interferance
Ok i've been told that i can use 4agze pistons in my 20v.
but it'll make the motor an interferance motor.?
if this is the case then what are the pros and cons of changing this?
Thanks for that any pros?
except for pistons being cheap as chips
ZE pistons and rods?
I'm not the greatest source of A series info, but aren't the 20v pistons and rods (I deffinately know the rods are) lighter than 16v ones to make them like the higher RPM!?
Yes the ZE pistons would be a bit stronger for boost, but is this really going to help you in an NA motor!? :dance:
well plans have changed since i have now been in a 20v powered ke. power not gonna do it.
so turbo route is happening. hence want to change to ze pistons.
i could spend like 1k on arias 20v pistons but for a lot cheaper the ze pistons will handle plenty of boost
you have to be very careful when putting the engine together or changing the timing belt to ensure you don't rotate the crank to hit and bend an open valve - this can be really annoying when doing such simple things as changing a timing belt!
Personally, i would avoid it.
You could get the GZE pistons flycut to avoid hitting valves?
what do you mean??
i have an HKS timing belt. on the way. the crank rods and pistons are getting balanced as soon as i sort out what pistons i'm gonna use.
fully rebuilt. the gze pistons i believe will drop the compression down to about 9:1 or 9.5:1
so plenty. ST are very strong motors.
yeah will have to talk to my engine builder about getting that done. thanks fellas.
Erm, what about the ceramic coating? If you fly cut through that you're going to create nice little hot spots. Even if you recoat them the thickness' will vary and you'll still have temperature differentials.
IMO don't use GZE pistons, splash out and do it properly the first time.
