HATER Posted July 30, 2009 Report Posted July 30, 2009 Hey guys you all should know this car it was WLD 02T I bought it a year ago. Things are going real well beside a few hick ups. My question is, I need to know what 15 inch wheels can fit on a standard stud pattern so I can run semi slicks Cheers Quote
HATER Posted July 30, 2009 Author Report Posted July 30, 2009 What struts and diff do you have ? Borg warner diff. Its running RA60 celica front end. Other then that thinking everything is is stock specs Quote
StasIII Posted July 30, 2009 Report Posted July 30, 2009 Ive got a set of 15inch rims off a lancer 2007 or 8 i think that fit my ke20 but ive got 5x114.3 pattern. maybe try the older model ones which have 4 stud. Quote
Taz_Rx Posted July 30, 2009 Report Posted July 30, 2009 I think your best bet is to pull out a tape measure and check your PCD. :D "Borg warner diff" doesn't tell us a lot. If the RA struts as unmodified then they would have 4x114.3 PCD. Stock KE20 PCD is 4x110, so if you discover it is still stock I suggest going shopping on Ausrotary. :D What motor is in it BTW? Quote
HATER Posted July 31, 2009 Author Report Posted July 31, 2009 Ive got a set of 15inch rims off a lancer 2007 or 8 i think that fit my ke20 but ive got 5x114.3 pattern. maybe try the older model ones which have 4 stud. Cheers ill look at it on the week end. Car has a SR20 in it. Quote
Matt-e30 Posted July 31, 2009 Report Posted July 31, 2009 Cheers ill look at it on the week end. Car has a SR20 in it. as for direct replacements there really arent any... late model Mazda Van rims fit 4x110 others that are close saab 4x108 (4 stud saabs obviously) Peugeot 207 307 4x108 Audi 80 4 x 108 there are a few more but these are the ones off the top of my head .. if you get a set of the 4x108 may be best to drill them out a bit and re-lipped for bolts.. they do fit on directly but some have experienced wheel studs bending... Quote
HATER Posted July 31, 2009 Author Report Posted July 31, 2009 as for direct replacements there really arent any... late model Mazda Van rims fit 4x110 others that are close saab 4x108 (4 stud saabs obviously) Peugeot 207 307 4x108 Audi 80 4 x 108 there are a few more but these are the ones off the top of my head .. if you get a set of the 4x108 may be best to drill them out a bit and re-lipped for bolts.. they do fit on directly but some have experienced wheel studs bending... Cheers heaps look into it on the weekend going to the wreckers then. Quote
bernieboy Posted July 31, 2009 Report Posted July 31, 2009 (edited) if you get a set of the 4x108 may be best to drill them out a bit and re-lipped for bolts.. they do fit on directly but some have experienced wheel studs bending... I have a set of Saab rims & have seen the wheels studs bend inwards. But they are off the car now. I would recommend you stray away from this option. Edited August 1, 2009 by bernieboy Quote
13BT_KE20 Posted August 1, 2009 Report Posted August 1, 2009 ive been using saab rims on my KE20 since mid last year without any problems Quote
Con-rolla Posted November 14, 2012 Report Posted November 14, 2012 hi mate i was wondering what size are these wheels? and are they the orignal stud pattern 4x110? thanks mate Quote
