can somebody confirm whether the ball joints in a ke20 fit into a ke10 lower control arm? I have the cars apart but it is a huge hassle to get the control arms down to a press especially if it doesn't work...
Robert.
I have some new KE1x balljoints coming by post, and some new KE2x ones in the shed so can specifically measure and compare in a couple of days.
I can tell you they are different part numbers.
Years ago when I worked as a parts interpreter I compared them side by side. The ke2x looked like they should press straight in, but have a different taper.
A mate tried it himself with the ke2x balljoints in one of his ke10's using the ke2x steering arms and ke2x struts. He said he ended up with even more positive camber than stock. He went back to the stock balljoints and struts with later brakes.
Edited by Felix
