August 19, 200917 yr comment_367320 They pivot at the top as the brake cylinder pushes out from the bottom.... Report
September 3, 200917 yr Author comment_371034 thanks Raven was bit hard to tell to untrained eye now the u mentioned it makes sence Report
September 3, 200917 yr comment_371070 Hopefully I've understood your problem correctly. You have very little travel, leaking and changed the cylinders. Just making a suggestion, have you bled the lines? Sounds a little like there is air in the lines because you have no travel. Once again, apologizing if i have misunderstood the problem. Report
September 3, 200917 yr Author comment_371072 yeah mate wasnt the problem bleed soooo many times every time i changed pistons obviously but yeah kept poping out just need new shoes with more meat on them and to adjust them bit tighter so that the cylinder wouldnt pop out Report
September 4, 200917 yr comment_371222 mine must have just wanted to make and arse of themselves i had new shoes and cylinders because i wore out the shoes from the handbrake i had the brakes adjusted up as tight as possible and the the hand brake backed right so i still don't know the reason sadly Report
