hey guys,
i drove about 250 km the other day and by the end of it the car was finding it hard to idle in 1, 2 or drive (its an auto), got REALLY bad about 10km from home, got ho,e and let her cool down.
poped the bonnet and the dizzy cap was 1/2 off not sure for how long but i fixed it up and thought nothing more of it.... oops...
ran rough the next day, so i took another look, points a little dirty, but centre point was FRIED and had black burnt looking plastic all over it and a "chipped" looking contact. i cleaned it all down. i check the plugs and gave them a scrub (will be getting new ones this weekend).
is there anything else i should check? its stock as a rock
picked up the gear this arvo...
the cap is to small and the leads look all wrong... i got them from repco and the guy said they where for a 4k.
can anyone tell me what brand/model/whatever i need to get? budget about $50-$80 for both (not each)
I have a feeling there are 2 different types of dizzy caps. the one to suit the nippon denso dizzy and the other to suit a Bosch.
this is correct,
if your not sure what your current dizzy cap/rotor button is is easy way to do it would be just take it in side and get it matched
ngk should cover ur points/plugs/leads
if ur still having troubles look in to ur coil as well
Does the car idle alright when it's in neutral??
yeah its "ok" i got the right cap now and ngk plugs, old leads are ok but i got a new set for spare just in case. runs good not but looks like the timing is advanced... i don't have the gear to fix it :P
this is correct,
yeah it a Bosch dizzy, the first cap was Bosch but to fit the other dizzy. now i have champion to fit Bosch...
yeah sounds right, Bosch make dizzy and caps as with champion they just make caps, points etc..
