Evan G Posted September 26, 2009 Report Posted September 26, 2009 should i try bashing the top of the sheer bolt with a hammer and punch to leave a impression in it then get it out with a screw driver? or just drill the whole thing out? Quote
Taz_Rx Posted September 28, 2009 Report Posted September 28, 2009 Yeah use a hammer and punch...... the long way Or, cut a small slot with a hack saw or dremel and undo them with a flat-head. :) Quote
Evan G Posted September 28, 2009 Author Report Posted September 28, 2009 thanks for the info :) Quote
Mick E Posted September 28, 2009 Report Posted September 28, 2009 thanks for the info :) get a set of easy outs or stud removers drill hole in bolt head put in easy out turn with shifter. less damage to other parts Quote
daggers57 Posted September 28, 2009 Report Posted September 28, 2009 should i try bashing the top of the sheer bolt with a hammer and punch to leave a impression in it then get it out with a screw driver? or just drill the whole thing out? [/quote I would use a VERY sharp nail punch and 'gently' tap the shear off bolts. Once they are slightly loose you should be able to remove them by hand. Once you hace them off cut a slot in the top so you can screw them back on. Don't worry about a thief being able to unscrew them and steal your car, there a many easier ways of doing that. :) P.S. I have been a Locksmith for over 10 years. If you have any other lock issues PM me. Quote
Evan G Posted September 29, 2009 Author Report Posted September 29, 2009 you beauty, ill pm you if i have any dramas. thanks mate Quote
