AE80Rollaguy Posted September 26, 2009 Report Share Posted September 26, 2009 My 4agze is starting to leak water externaly and i think i should fix this asap just wondering if the 4age head gasket will fit the 4agze?? Quote Link to comment Share on other sites More sharing options...
Roo Posted September 26, 2009 Report Share Posted September 26, 2009 yep just did it on my 4agze and used a 4age one Quote Link to comment Share on other sites More sharing options...
AE80Rollaguy Posted September 26, 2009 Author Report Share Posted September 26, 2009 aww good stuff man!! yeah ebay have listings for 4agze/4age head gaskets, what thickness did you use?? and is it hard to do it? what other gasket will i need? eg inlet, exhaust ect ect sorry for all the questions i just like to be prepared Cheers Quote Link to comment Share on other sites More sharing options...
Roo Posted September 27, 2009 Report Share Posted September 27, 2009 um you need exhaust and intake gaskets, need to get some bluemax for the front water fitting. could do the cam cover gaskets and stuff too. not sure the thickness of mine, you will need a deep 10mm 12hex socket to undo head bolts and cam bolts Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted September 27, 2009 Report Share Posted September 27, 2009 standard for all 4age is 1.2mm compressed. Quote Link to comment Share on other sites More sharing options...
AE80Rollaguy Posted September 27, 2009 Author Report Share Posted September 27, 2009 standard for all 4age is 1.2mm compressed. thanks mate, just a question why do people put thicker gaskets on? Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted September 27, 2009 Report Share Posted September 27, 2009 to lower compression and hance be able to run more boost. Although it works it's a flawed approach Quote Link to comment Share on other sites More sharing options...
Evan G Posted September 27, 2009 Report Share Posted September 27, 2009 to lower the compression of the engine therefore more boost Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted September 27, 2009 Report Share Posted September 27, 2009 Try getting a hold of a top end gasket kit (VRS?) Will have every gasket you need from the head gasket up. I was looking for a headgasket and manifold gasket for my ute and it was like $40. compared to a top end kit that had all the gaskets i needed for $44.50. so it will probably work out cheaper. Quote Link to comment Share on other sites More sharing options...
AE80Rollaguy Posted September 27, 2009 Author Report Share Posted September 27, 2009 a ful vrs kit for a 4agze is hard to find Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted September 27, 2009 Report Share Posted September 27, 2009 fair enough then. Nothing out of J-land or US of A? Quote Link to comment Share on other sites More sharing options...
AE80Rollaguy Posted September 28, 2009 Author Report Share Posted September 28, 2009 fair enough then. Nothing out of J-land or US of A? there are FULL gasket kits on ebay for like 400 bucks!!! but over the top but hey id have Every gasket under the sun, Would any one want to do my headgasket for me? Quote Link to comment Share on other sites More sharing options...
