June 14, 200521 yr comment_50326 is it a simple job of converting the ke71 to a ke70 by just replacing the panels, head lights and grill, or is there more involved structurely? Also who wants ke71 cloth seats front and rear??? Report
June 14, 200521 yr comment_50383 Ke71 ? Are you talking about the early edition front end (ke70) to the later edition (Ke70 & Ae71) ? I THINK med man looked into this... ill let him comment. Report
June 14, 200521 yr comment_50453 yes there is, i've seen at least two in the wreckers, and one driving around registered the chassis code isn't ke71 tho, that's just a term people use to describe the update front end Report
June 14, 200521 yr comment_50481 ooh, bout those seats, where are u???? adelaide?? ? ? ? ? ? !!! ??? Report
June 15, 200521 yr Author comment_50543 yeah sorry i want to put the smaller head light and grill setup in the later model that has the bigger head lights. I'm in brisbane alexandra hills to be precise. Report
June 15, 200521 yr comment_50547 Simple answer, don't waste your time, keep your car the way it is or just get another car the shape you want. The bits don't just swap over from one to the other.. You will have to cut out and weld on the whole front radiator support to allow it to fit the AE71 shape front end. The difference between the early and late front ends. The bonnet Guards Front apron Radiator support Grille Front bumper bar Headlights Indicator Lights I think you will find there is no such thing as KE71 in australia, most likely that the difference on the firewall is KE70 as opposed to KE70E? Report
