Ae71 Show Car Converting To Drift Slut
niiko101
Engine: 4A-GE 20valve ( Needs After Market ECU)
Exhaust: TRD Extractors With 2.25inch All Through With 3inch Tip
Suspension: White Line Sway Bars, Strut Brace With Stock Shocks and Cut Springs Not Very Nice ( Want Cheap KE70 Kings Front And Rear And Also Camber Top For Front For Now)
Wheels: 18inch Somethings ( Want Tanky Drift Wheels With Good Offset Hopefully White Rota Grids )
Modifications: 20valve, Full Tan Interior, Paint, Wheels, Tail Shaft ect ect
Stereo Audio / Visual: Pioneer DVD With MTX Splits
Estimated Power: Not Sure
Just Posting This To See What Ideas People Give Me On How To Do it To Make It A Show Drifter
Wanting To Do To The Car
*Fully Adjustable Coil Overs
*16x8 White Rota Grids
*Microtech ECU
*Remove as much unwanted plastics as possible
*Convert Cluster To Full AutoMeter Set Up
*Door Trims To Sheet Metal
*Quad Light Conversion
*Front And Rear Chrome Bar And Front Bottom Lip Like Grant Scotts AE71/KE70
Just Throw some ideas my way
Edited by niiko101
  • Replies 55
I don't even want to think about all the things wrong with that 20V installation. Like Sam said that cooling system leaves a little to be desired and you could have had a much cleaner, neat install with a few custom parts off here. Prob cheaper than that big arse pipe you have running all the way from the back to the front. I wonder how effective that will really be being so long :S
Lighten up Luke :yes:
Yeah on reading it again it was a bit harsh. New baby = no sleep :wink:
Mate you probably need to look into some other options for the cooling system, if you need any help you can PM me and I can tell you the parts I used. Mine worked flawlessly and was a bit tidier in the engine bay :y:
Smeetsy, better?? :hmm:
Yeah on reading it again it was a bit harsh. New baby = no sleep :yes:
Mate you probably need to look into some other options for the cooling system, if you need any help you can PM me and I can tell you the parts I used. Mine worked flawlessly and was a bit tidier in the engine bay :hmm:
Smeetsy, better?? :wink:
yea it needs work bought car as is and gona to make it a drift slut. do need some help tho as i am only new to toyotas and 4AGE conversions
