October 26, 200917 yr comment_385590 Hey guys!! some of u may know that recently i got my self a ae93 gze rolla! so here is the deal, clutch is on the what out... now i know there are a few different clutch sizes and what not in this area, if some one could help me to find the right clutch for my car that would be muchly gratefull :> i would probs need spline size and how many teeth ect so i can let repco or bursons know i need to know before i pull it out because ill be doing it at work one weekend and don't really have another car to get around in if i need to orderparts Cheers tory! Ps: 4agze 16v, map sensor, not to sure on the other details.. so if u need more just ask me and ill find out and would it be worth my while to get a heavy duty clutch? Edited October 26, 200917 yr by AE80Rollaguy Report
October 26, 200917 yr comment_385596 you need to measure the diameter of the friction surface, know how to do that? the outside of your abrasive material on your friction plate would be a fairly accurate way to go Report
October 26, 200917 yr Author comment_385599 yeah, thing is i wanna get the right one before i pull it apart :yes:, are the na 4age's the same? Report
October 26, 200917 yr comment_385609 being a fwd there are 4 possible sizes: 200, 212, 225, 230mm so no Report
October 26, 200917 yr Author comment_385612 if i knew my type of gearbox would that help?? its the lsd version Report
October 26, 200917 yr comment_385629 no, afterall all are interchangable so someone could of swapped it Report
October 26, 200917 yr Author comment_385631 no, afterall all are interchangable so someone could of swapped it This is true man! so if i order one of each kit i should be right haha!! Whats the most common do you think?? ive had a look round the splines are the same by the looks of it, but just the clutch diameter varies Report
October 26, 200917 yr comment_385639 Does much of this info apply acros the board? Got a similar problem and need for info on my ae92 4AF engined car (see the thread further down) Report
October 26, 200917 yr comment_385709 Majority of the factory supercharged engines had the 234mm I think( or whatever the factory 4agze came with). but as yours is the ae93 which didnt come with it stock, there is no way to tell without pulling it apart. With the guy with the 4af, it's most likely the stock one. Report
October 27, 200917 yr comment_385921 get a 234mm clutch plate as that what must likely be behind a fwd 4agze Report
October 28, 200917 yr comment_386180 there is no 234mm that I know of, only 225 and 230 for the ZE engines. All FE engines have a 6 bolt crank my short guide: http://s-86.com/s-flywheels.html Report
October 28, 200917 yr comment_386261 there is no 234mm that I know of, only 225 and 230 for the ZE engines. All FE engines have a 6 bolt crank my short guide: http://s-86.com/s-flywheels.html my bad meant to say 224mm Report
November 4, 200916 yr comment_388044 Hey, heavy duty clutches are good, just don't get a PRB Clutch Industries clutch of any variety with a powerful car, slip it once and get the friction material hot and they slip for ever more. As everyone said, there's no way to be 100% certain until you remove the motor from the gearbox. There's a chance they may have been lazy and just used the factory gearbox. BTW All the atmo 4A's have the same spline, but I'm fairly sure though the GZE has a bigger spline. Report
November 4, 200916 yr comment_388059 Straight off Exedy's web page - 4AGE 24.1mm x 21 spline 4AGZE 28.9mm X 21 spline (Same as a W55) Report
