Lpg Turbo 5k
Just make an offer on the T25.....
I was going to use it on my 5k.....
It is a nice sized turbo and if set up right, it would make some really nice useable power! :D
  • Replies 36
  • Views 34.2k
Lol, I blew my rings yesterday. Gonna slap whitey's 4K block in for a while, so It's time to rebuild the 5K for the blower. Been pricing some new ACL pistons too. Pretty good deal. I think I'm gonna keep as much capacity as possible over running the skyline pistons, the more gas to spin the turbo the better.
how much are you paying for ACLs? my 060 4k pistons were $161.90 repco cost price
skyline pistons? they go in a 5k? from what engine?
Yeah I was gonna get my mate to get me cost repco ones too. The Rb20det pistons aren't a direct fit. I was gonna get the bores machined a few mm's and get it sleeved at my mates workshop.
Will I make more torque with heavy skyline pisons and a 1.4 capacity? Being a turbo motor there's always downforce on the pistons, so it should hold together ok.
so rb20 pistons are of a smaller bore than 5k pistons? you'll make less torque with less capacity. i'd say it's more trouble and expense than it's worth
really the weak point isn't the pistons, it's the rods and crank. some people reckon you can use 1G rods and pistons in a 4K, so you'd be able to use the rods in a 5K
generally you can force just under half a bar into a stock K engine and it won't effect it too much. wind that up to say 10psi and things will go bang regularly
Edited by Super Jamie
So you still after that turbo for your project beerman???
:jamie:
Hells yes, when are you down
Not to sure, maybe just cruzin down for a quick trip soon.....
I'm installing my new 5k in a week, so ill be held up for a little while....
View - Rolln03 is coming to Brissy post in a few weeks.! :jamie:
Cheers Jamie,
Do you or anyone know the size of the 1g gudgeon pins? Thinking along the lines of 81mm 4AGZE pistons (20mm gudgeon) and 1G rods with that new piece of information.
not off hand, but it could possibly be in the ACL piston catalog, which you can download in pdf off their website http://www.acl.com.au/
from memory it's not in there tho. i googled and found something i wrote myself on this message board :jamie:
couldn't find any info except to say they're the same bore and have the same number of rings and ring size as a 4k, and someone who thought 1G has a 20mm wrist pin as opposed to 18mm 4k. if you could find a catalog with pistons or rod bearings for a cressida or mark ii you could confirm
I googled till I couldn't google any more. There are hits with the right keywords, but they're about 10 posts away from each other in the messages.
:jamie:
yeah, it's something i've never been able to find either. maybe a mechanic at an importers could tell you, or lexus dealer service would have access to manuals that would have it
toycrash is the new king of google :jamie:
that's for n/a motors tho. the forced 1G-GTE and GZEs may be stronger. you'll notice later generation smallport 4AGEs (and GZEs) have a 20mm wrist pin, whilst the early bigports are 18mm
