October 27, 201114 yr Author comment_562984 new tyres showed up today 255/60 15 et streets also new 8 inch bands for my new rims. at the moment i only have 235 on a 7 inch rim so should give me a little more road contact and traction hopefully. also got my custom springs made to stop it squating so much the springs i have at the moment are 185 pound and the new ones are 230 pound, no body could really give me an answer on what spring rate to go to so it was a bit of a guess so time will tell how well they work. i could have gone stiffer but i still want it to be comfortable Report
October 30, 201114 yr comment_563539 what are you doing with the 235's there much life left in them ?? Report
October 31, 201114 yr Author comment_563646 keeping the 235's as well for the street atleast they sort of get traction, normal tires you can't even boost it without them spinning Report
November 6, 201114 yr Author comment_564666 new turbo time in next couple of weeks (ended up getting a pt6765 billet precision), first were going to dyno it again with my current turbo (t66) at 30psi then dyno it with a t04z without changing anything else then dyno it with the precision turbo to see the differences between the 3. they are all basically the same wheel sizes just different design so will be interesting Report
November 14, 201114 yr comment_566189 Keen to see the results of the 3, heard good things about those precision turbos. Report
November 15, 201114 yr Author comment_566275 yeh I'm thinking that the precision will go around 50hp more on the same boost and the other two will be about the same Report
November 25, 201114 yr Author comment_568139 did a couple of dyno ramps today with the old turbo before it got pulled off and made 567rwhp on 26psi, its still really hard to get it to not spin the tires on the dyno but hopefully will get some sort of back to back testing. will do the t04z in the morning with the same boost then precision turbo will either be tomorrow or early next week Report
November 26, 201114 yr Author comment_568242 so tested garrett t66 vs to4z and results are pretty well as i thought, turbos are identical only difference is plain bearing for t66 and ball bearing for to4z. turbo was changed while the car was still strapped on dyno same tune nothing changed, t66 actually made 7 hp more on 2 pound less boost but its close enough to call them same. for all you die hard ball bearing turbo lovers it was definately no better for lag. will be testing new turbo next week Report
December 1, 201114 yr Author comment_569169 had to move wastegae and remake part of the dump pipe but its all done ready for some dyno time Report
December 1, 201114 yr comment_569186 Mr Sleeper, Sir. Wondering where you got your rim bands from and what'd they set you back? Report
December 2, 201114 yr Author comment_569257 Mr Sleeper, Sir. Wondering where you got your rim bands from and what'd they set you back? race engineering Report
